IXU27 Denso plugs for RXP/SC 4TEC
  • IXU27 Denso plugs for RXP/SC 4TEC
    For those using the new high flow intake packages on the Sea-Doo RXP or SC 4-TEC, it is advisable to use one-heat range colder plugs. These are $11.99 each though either www.sparkplugs.com or www.deniskirk.com just search for part ixu27. The help prevent detonation from the slightly leaner air/fuel mixture.
    Re: IXU27 Denso plugs for RXP/SC 4TEC
    Whats your opinion on the NGK Iridium plug? It's a BR8EIX and can be had for about 5 bucks each. Not the same as you mentioned but same type. Just looking for and opinion.
      If that's the cross-refernce plug go for it! NGK is awesome!
