Pro X or WSM performance pistons
  • Pro X or WSM performance pistons
    Simple question, which is better and is it worth the extra $20-30 for the Pro X pistons?
    Re: Pro X or WSM performance pistons
    Definitely Pro-X over WSM. We use our own which are just like OEM.
      Ok, thanks. I would just buy from you guys but you don't sell an 82.25 piston.
      Thanks.
      Just curious, whats the difference?
        i have used 100s of WSM pistons without failure .
          Different metals, different dimensions.
            Pro X Without A Doubt. I Have Used Them For Yrs And Built Hi Perf Motors With Them With No Failures.
              Thanks for the replies, I guess I will go with the Pro X. One more question about the differences, Is there any performance differances or is it just build quality/materials. Both companies say they are designed to OEM specs except the WSM Performance Platinum Series.
                Performance as in power? No.
                  I tried WSM's one time in a Polaris motor. The ring lands on the piston broke in an hour running time....... Never used them again. Pro-X makes excellent high silicone content cast aluminum alloy pistons that have always given me good service. I have used several sets of SBT pistons too without problems.
                    What about Wiseco pistons are they any good? being forged arenīt they appropriate for modified engines?
                      Quality wise, Wiseco are fine. User-wise, they are usually not. It takes someone familiar with them to set the motor up, with the appropraite larger clearances, and a user familiar with them to know how long to appropriately warm the engine up before doing any hard riding. Otherwise you get a nice hard seize.
                      I only recommend them to experienced builders/tuners/riders, NOT a recreational ski.
                        Forged pistons are excellent high performance pistons for use in a racing motor.
                        Cast aluminum pistons are excellent pistons to use in a recreational motor that needs to run for hundreds of hours with tighter clearances, Quietier operation and less piston rattle.
                        • #13
                          I am currently rebuilding GP 1200 with Wiseco Hot Rod crank assy. & Wiseco pistons. Doing myself with guidance from PR Racing Engines here in Toledo,OH. who also bored & ported cyls. for me. Will hope for the best & advise when completed.
                          • #14
                            I have had nothing but good results using Wisecos for 2 and 4 stroke rec. applications
                            • #15
                              i hope your right quickSX/XP. I"m tryin to stay reliable but max perf. thinking bout milled & squished stock head to boost comp & hp & maybe aft, reed set for xtra throttle response. Looking to hang buddies 1300r. We,ll see ! (62 mph gps ) Figure that out! Already do it out of the hole, now want to get him on straight shot.:D
