If I were to install the R & D timing advance plate on my 2003 sxr, will the carb need to be re-tuned? I don't think that it will, but I just want to make sure before I order the kit. Also does the O-ring that came stock with the boat, or the gasket style seal that comes with the r & d timing advance provide a better seal? I have had problems with water getting into my genrator cover and now the fly wheel and stator have a little bit of rust on them. The dealer replaced the starter bendix under warranty becuase of the bendix rusting and freezing up. The reason why I want to add the kit is that I have pulled off the generator cover to check out what it looks like in there and to see if I coudn't clean it up a little. When I pulled it off I found that the stupid dealer used silcone to provide a seal around the O-ring instead of grease for the generator cover. I can order a new O-ring from my local dealer for close to $20.00 with tax or order an advance timing kit that comes with a gasket style seal instead of an O-ring for $45.00. Just need help in deciding what which seal I want to put back on there. THanks again.
Chris
805 Wave pavers
Chris
805 Wave pavers
