I think that my reeds is crap, and should really need some help here! :)
Ski set-up: -90 Superjet with 701 cylinders (61X) Wiseco pistons, ADA head, Pro tec pipe, no water box, pro tec CDI, MSD ignition coil, kawasaki 750 intake welded onto the crank, boysen pro series reeds, two 46mm mikunis and riva f/a.
This is how the ski is behaving:
After warm up it runs nearly perfekt, but efter a few minutes it starts to feel very rich att full throttel. And after ca 15min of riding it is going like crap over 60% throttel. The best speed is reached at around 50-60% throttel. I dont think that its the carbs, i have tried to tune them but i wont help. And on top of that, they are brand new (Mikuni 46mm) and the ski is running exactly the same as before. (when i had my old 44 mikunis)
I had Boysen Pro Series reeds on, but i also tested with the stock reeds but it didn´t do any big diffrence. It runs a little bit better, but is harder to start. (None of the reeds seald compleatly against the "reed valve body")
Do you guys think that its the reeds causing this?? And in that case, wich reeds should i buy?
Sry for my bad english.
