I have a bone stock 2001 RX DI with 120 hrs that I want to start modifying for a quicker hole shot and better midrange without doing major engine mods. I'm considering changing the stock impeller to a Solas Dynafly ST-DF-12/18 because, even though the ski is already a respectable performer, my rpms never exceed 6950 at WOT so I feel I can drop pitch for better low and mid range acceleration without hitting the limiter. I don't care as much about top speed. I spent a lot of time optimizing the rave valve settings and here is my best results from the last run of the season using a Garman GPS-72:
water temp: 68 degrees/air temp: 80 degrees- flat water, dead calm
1/4 tank of Shell V-Power 93 octane, Amsoil Interceptor synthetic 2-stroke.
61.5mph@6950 rpms with 200lb rider and gear (no stopwatch, but about 12 seconds to top speed)
I'm also considering an R&D rideplate and intake grate to keep the pump loaded and improve handling. The pump doesn't cavitate out of the hole, but it doesn't stay hooked up very well in rough, choppy water.
Any thoughts or opinions on the impeller selection? Are there other ways to get better bolt-on holeshot performance?
