Ok so I have a 1997 Waveventure 1100 with 126hours on the clock. Everything runs perfect and I can get it up to 57mph tops on a clear day. Plus I weigh 228lbs. Is this a decent speed. Also is the 1100 a good engine. When I first bought it with 120hours I removed the oil injection and run a 40/1 mixture.
Issue:
I was looking at the Honda PWC and the new FX140 but from what I am seeing they run about the same MPH except for the turbo model.
The 1997 Waveventure 1100 looks alot like the XL1200 and XL700 are they somewhat the same ??
Last but not least heres the technical question:
My friend has a 1995 Waveraider 1100 with 175hous. I also removed his oil injection pump when he bought it at the first part of this summer. His raider runs awsome at full speed (63mph) but when you first take off after idling it wants to bog down and shut off. If you pull the choke out just alittle it picks right up and goes great. It also idles fine too. The ski had sat for 1 year to 2 years before he bought it and it did have fuel stablizer in it. I drained the tank before we went out in it. He has been to the lake 4 times already running about a total of 5 hours and the ski still does the same. I work on small engines all the time but if the carbs need rebuilding then why does it idle and run at full speed fine ??
Thanks for the awesome board y'll have!!!!
Issue:
