900ZXi Torque Specs
  • 900ZXi Torque Specs
    I am about to reassemble a 900ZXi motor and need the torque specs for the cases, cylinder and head. Also, some of the gaskets appear to be a metal or plastic based with a coating one them (OEM and Cometic). Should these be coated? Also, what is the best way to prime the oil pump lines after bleeding it? Thanks for the help.
    [ August 07, 2003, 02:10 PM: Message edited by: Zebra ]
    These are the specs for the 1100:
    Crankcase - 6mm dia = 78 in lbs
    Crankcase - 8mm dia = 22 FT lbs
    Magneto cover bolts = 94 FT lbs
    Magneto cooling cover = 78 in lbs
    Stator mount bolts = 8.5 FT lbs
    Flywheel bolts = 94 FT lbs
    Coupling = 94 FT lbs
    Cylinder base nuts = 25 FT lbs
    Cylinder head nuts = 22 FT lbs
    Cable holder bolts = 14.5 FT lbs
    Water pipie joint = 8.5 FT lbs
    Exhaust pipe mount bolts = 36 FT lbs
    Exhaust manifold nuts = 14.5 FT lbs
    Expansion chamber bolts = 36 FT lbs
    Intake manifold bolts = 87 in lbs
    Carb mounting bolts = 78 in lbs
    Air intake mounting bolts = 69 in lbs
    Arrestor case stay bolts = 78 in lbs
    Throttle case mount bolts = 78 in lbs
      Anyone with a 900 manual, please check these values, and post either a confirmation of them, or corrected values.
      Instead of retyping the complete list, follow the same order, just type the first letter of the item, followed by either the corrected value, or OK if it is correct.
      Example:
      C = OK (for Crankcase - 6mm dia = 78 in lbs)
      C = 20 FT lbs (for Crankcase - 8mm dia = 22 FT lbs)
      M = 92 FT lbs (for Magneto cover bolts = 94 FT lbs)
      Bill
        I think they should be the same, but it would be great for someone to confirm. Thanks.
          andy v,
          Good call! My mistake, I entered the data for the coupling, which was for the line above.
            "Magneto cover bolts = 94 FT lbs"
            that's a 6mm thread!
            try the 78" lbs instead [img]graemlins/spit.gif[/img]
            go away now please!
