I have a kawasaki 550 but the engine has gone to pot, a friend of mine has a kawasaki 650 in a broken hull. He has sold all the jet drive electrics etc. What bits do i need to put the 650 engine into my hull. Is it just a case of swapping the engine or what else is involved? Thanks for taking the time to reply. Just could do with sorting the ski out for this eason.
Kawasaki 550 engine swap.
you can even install the 650 into the 550 using the 550s electrics. You would need the regulator from the 650 but other than that, you can use the 550 electrics.
An advantage of this method is that you dont have to fabricate mounts for the 650 electrics and you dont have to go with aftermarket coils to remove the rev limiter if you are looking for higher performance.
Let me know if you would like a wiring diagram for this installation.
oh, and people have had good luck with using the westcoast pipes on this conversion.. Some pipes are very difficult to fit into the 550 hulls.
If you want to use a factory 650 pipe just make sure you have the one that has two rubber couplers on it. There were two different pipes that came stock on the 650SX the one with two rubber couplers works.
