first off what do I need to do to it before taking it out?
I will change the jet pump oil and air filter, plugs, and wires, battery.
Are there fittings on the driveshaft I need to grease like on my seadoo? also what kind of oil should I use in it to mix? is pennzoil okay at walmart? what is the correct mixing ratio? It has synthetic oil in it now with 50 to 1 ration and the guy i got it from said it was a lil rich, but he only got to ride it for a short time.
I ended up getting it for $320!!!!!!!!
and it has been indoor storage since 95, we drained all the oil and gas and put fresh stuff in and it fired right up, took the head off and the walls and pistons look brand new. Comp was 130 psi on each cyl.
Sorry for rambling on, tell me what I should do Thanks
