I finally got my new SBT engine in and the second day out the trim got to where it will barely move. With the trim box cover off I can see the end of the cable makes about a quarter of a turn then stops when you press the switch. The mechanic that installed the new engine sprayed some Bombe anti corrosive stuff in the box, as I found water in it while the engine was out. Today I took the cover back off and coated it with WD-40 and left it open to dry some. Any ideas on what might correct the issue?
Thanks
Thanks
