Hi folks,
I was wondering if anyone could with advice on bearing and impeller replacement and checks.
The problem started when I was zipping about in the North sea Scotland (COLD) and I heard a whining noise from my ski, I limped back to the harbour and home to the garage where I stripped out the pump housing and impeller to discover that the bearing located under the cone section at the rear of the housing had totally disintegrated. Due to this bearing going the shaft had play and had been moving forward under load, this has caused the impeller to contact with the pump housing.
The problem being that I have no comparison for checking how much of the impeller material has been lost, the impeller that was fitted was a SOLAS 16/20.
The other thing is due to the impeller moving forward under load there may be some wear on the pump housing, what sort of problems could this cause and how would I check to ensure that it is OK?
Finally if I need to replace the bearing at the cone section, what other bearings or seals would you advise me to change when the component is stripped down.
P.S is there any oil levels that I should check or fill on a regular basis, as I cant find any fill point on the engine.
Please excuse the amount of questions but I am new to DIY ski repairs.
Thanks for your help! :emoticont
Tfun
Tfun
