I recently replaced the engine in my 1998 Kawasaki 1100 STX with a rebuilt engine from SBT (this is the second one, the first one overheated and seized due to an obstruction in the cooling system per the SBT analysis). In both cases, after the SBT engines were installed, the #1 cylinder seems to run much hotter than 2 or 3 when using the flush fitting. I am positive the original engine did not do that. Is that a sign of trouble to come when I start breaking the engine in? I realize the flow is different when cooling water comes from the jet pump, but am concerned since the original engine did not do this and my first SBT engine overheated.
Also - where can I get a clear diagram of how water flows from the jet pump, through the exhaust and engine block/heads and back out?
