does anyone know where the fuel pump is i cant find it or the relay if it even has one. it has spark and it will run on starting fluid but there is no fuel. any help would be appreciated. thanks
96 750SS no fuel
Re: 96 750SS no fuel
Fuel pump is mounted on the back of the carb, trace fuel lines from the tank to the water sep. to the on/off valve to the carb and thats the fuel pump. Run a fuel line directly from the fuel tank to the fuel pump, you may have an issue with the water sep or with the on/off valve so by pass them.SBT Tech Support is here to help with your problems.
