kawasaki sts fuel issue
  • kawasaki sts fuel issue
    kawasaki sts 1995 got very hot because water cooling tube came off and flooded engine compartment.
    it cranks but won't start.compression is ok and spoark plug has good spark. fuel is not coming from tank into carburator.. what is the cause? how do i pinpoint the problem?
    thanks
    Re: kawasaki sts fuel issue
    Check your pulse line on the crank case and check sending unit in the fuel tank.
      they are fine
