I'm having the cylinders of my '93 Kawasaki 550sx Jet Ski match-bored for new pistons. The machine shop needs the original OEM cylinder size statistics (diameter, clearances, etc.) before they can begin. Can anyone provide these for me please? Thanks - Mike
1993 550sx Cylinder Clearances - OEM
Re: 1993 550sx Cylinder Clearances - OEM
i dont hav ethe original specs for that model but its 3-4 thousands clearance .003-.004 for the bore with the new new pistons and
here are the bore sizes so you can give them this list and they can measure the cylinder and then beable to figure out what size your going to be from there
http://www.wiseco.com/ProductSearch.aspx
608M07500$116.97 75.00mm STD Cylinders:
2Displacement:
531ccStroke:
60.00mmNotes:
Cylinder Reed 608M07550 $116.97 75.50mm 0.50 Cylinders:
2Displacement:
537ccStroke:
60.00mmNotes:
Cylinder Reed 608M07600 $116.97 76.00mm 1.00 Cylinders:
2Displacement:
544ccStroke:
60.00mmNotes:
Cylinder Reed 608M07650 $127.30 76.50mm 1.50 Cylinders:
2Displacement:
551ccStroke:
60.00mmNotes:
Cylinder Reed, Crankcase cleanup req 608M07700 $127.30 77.00mm 2.00 Cylinders:
2Displacement:
559ccStroke:
60.00mm
hope this helpsjoe D Mst Motorsports www.mstmotorsports.com
your welcomejoe D Mst Motorsports www.mstmotorsports.com
By the way, Joe.... I checked out your website. Very nice site. I don't have much use for winterizing here in Florida, but if I did, I'd know who to call. Hope the other viewers here on SBT will take a peek at http://www.mstmotorsports.com/ . Anyone who takes the time to help someone a thousand miles away is obviously the kind of person who's going to give excellent customer service to his customers. Cheers! - Mike
