I have a 92 750sx that i recently bought. The engine had not been run in while so I pulled it apart to reseal the motor. When I was putting the top end back on I cracked a ring. I'm pretty sure the motor does not have the stock bore. The only markings on the piston are "100" on the top center of the piston. Does this mean its bored over? What size would this be? Any help would be great so I get a new set of rings and get this thing on the water!
750sx piston ring size
Re: 750sx piston ring size
sounds like 1mm over bore see who's piston it is so you can get the correct rings for it. What name or markings are on the piston?SBT Tech Support is here to help with your problems.
sounds like O.E. pistons that are 1 over, you will need to get O.E. rings, Not aftermarketSBT Tech Support is here to help with your problems.
