STX 12F Will not go over 4000 rpm
  • STX 12F Will not go over 4000 rpm
    I have a 2006 STX 12F. I had a very difficult time getting it started this year, once I got it started I took it out and it will only turn 4000 rpm. It goes right to 4k and just sits there.
    Any help would be greatly appreciated.
    Re: STX 12F Will not go over 4000 rpm
    Try fresh gas, new plugs, If that doesn't help you should then have Kawasaki do a diagnostic test on it.
      Thank you for the quick response.
      I put new plugs, pumped out all the old gas, and put in a new filter at the direction of Kawasaki.
      They also checked and there are no codes or faults.
      I find it very odd that it will run right up to 4kabout and not 1 rpm over.
        I forgot to add the engine runs up to 7000k out of the water.
          Clogg in the exhaust.
