Would this sleeve be acceptable to use on a 250x ultra 2008 ????
Kawasaki 15 f Sleeve Code: 44-213
Re: Kawasaki 15 f Sleeve Code: 44-213
Not sure, we use the sleeves on the 12f and 15f it would most likely work but major machining will need to be done since you have to hog out the nicasil to fit it properly.SBT Tech Support is here to help with your problems.
