Hey Dan,
MAN!! The advance plate is not that easy to install. If I'm right, the plate is first design for the SX. The instruction looks so simple but for my SXI I had to get out the Dremel and grind some clearence off the cover and pickup. My question is, the advance plate thickness move the pickup in a little will it not lined up with the triggers on the flywheel good now? I started up and it ran, throttle sounds crisp and clean so I guess it's ok for now. I know the R&D advance plate comes with a thick gasket to compensate, should I go find a thick gasket?
Thanks,
Mike
Thanks,
Mike
