I have 1995 SL750. I just got the new 3 output fuel pump today. In the other threads it shows where to run the new fuel lines and which to block off. but in the diagram it does not show the fuel return line that goes back to the fuel tank. Do I need to mess with this line or just leave it alone.
fuel pump
Re: fuel pump
There's no need to change anything about the return line. In case you decide to replace the return line while you're doing this work in that area, there's a restrictor inside the return line near the connection to the fuel rack. It should stay there. In other words don't accidentally throw it away.Zipper<br />'95 Polaris SLT 750<br />Rockmart, GA
