Idle in water 1200-1300
Idle needle 1/2 turn out (All)
High-speed needle
Front 1 1/4 turn out
Center 3/8 turn out
Rear 7/8 turn out
This is from Clymer so take it with a grain of salt
I did not think there would be that much variance between the cylinders on the high speed adjustment... Thank you though. I just installed the add-on fuel pump. I've got 1 year old gas in it, so i'm gonna start there... and pull the carbs if needed... Can i screw in #1 a little since i have the extra fuel pump???
Heya Tech, why the difference between '94 and '95 ?
Bart, those settings are assuming you're getting fuel. I see what you mean by wondering if you should turn it in, but only if they were turned out before. Just set it to spec. You may have to fine tune afterwards, but not more than 1/8th turn.
thanks, you guy's are super-duper. I know you're out there to make money in your field, but geez. You're a HUGE asset to our sport !!!!!! Without this good advice, so many people would be sunk.
