i have had the ski out of service for 2 years. i took it out and it seems to be running on only 2 cylinders or something. It takes off slow and only tops out at 35 mph at 5000 rpms. the 1 and 2 cylinders are scolding hot and 3 s just mildly warm. What are my options? I already replaced the plugs and tried to reset the system be dsconnecting the battery. I also have cut the fuel electrical line to try and bypass the possible limp mode. Dont know what to do next.
97 sltx 1050 problems
Re: 97 sltx 1050 problems
I'd do a compression check 1st, just to make sure the motors OK. assuming compompression is OK 120+ psi in each cyl, then prolly the reason #3 is cooler is coz its getting not enough spark, or too much gas. check the spark 1st. hook the thing up to #3 and ride it and watch the lite. make sure its sparking all the time. If it is, then you might need a carb clean - leaking needle valve.<a href="http://www.wetwolf.com/" target="_new"><img src="http://www.wetwolf.com/images/hurrsigpic.gif" width="400" height="100"></a><br /><br />Bruce Wolford<br />Wet Wolf Technologies - Purveyor of Performance Pump Parts<br />(509) 280-5444<br /><a href="http://www.wetwolf.com" target="_blank">Wet Wolf Tech</a><br /><br />PWC Race Director<br />Northwest Water Competition<br /> <a href="http://www.nwh2oracer.com/ijsba" target="_blank">http://www.nwh2oracer.com</a>
I betcha you got a carb that needs rebuilt, if not all of them. On my 750, I could only go 5200 rpm and it was a bad pump diaghragm in the center carb. My sign was the plug was covered in a little clean oil. Looked like it hadn't been firing, but I had spark. Just wasn't getting gas, the diaghragms had gotten hard.
I am leaning towards the possible carb problem. is it hard to do a carb cleaning. i have cleaned carbs on a lawn mower but nothing else. the reason the ski was out of service was because of a whole in the shell. water flooded the ski but almost positive did not reach the carbs or cylinders. #3 when checked last week had a few tiny drops of fluid but I think that was just gas. My guess would be the carbs need cleaned. I dont thnk they have ever been cleaned. please advise and possibly point me to some carb cleaning directions
thanks
