SL 780 Speeds and RPM
  • SL 780 Speeds and RPM
    What kind of Top End speeds should I be getting from an SL780 and what RPM should it be running at WOT?
    Rider = 250 lbs (no wisecracks :P )
    Re: SL 780 Speeds and RPM
    52 Mph @ 6750 if tuned and running properly
    WATERCRAFT SERVICES. PROVIDING THE RESIDENTS OF HOUSTON AND SURROUNDING AREAS WITH QUALITY WORK ON THEIR PWC AT A FAIR PRICE.
      So if I'm running at WOT on a nice little chop or even smooth water the RPMs should be that high? They only get close to that when impeller comes out of the water.
      What could cause the lower RPMs (~ 5500 WOT)
      Could low compression? Right from the day I got the motor (SBT) the compression was 110 across the board which seemed a little low but I wanted to confirm with another guage.
        I have a SLT780, it hits just above 6300rpms at WOT...I am not sure if everything is correct? Max speed if my speed sensor is working properly is aprox. 50mph
          I've Got a 94 SL750 , a new NuJet 5.0 impeller. The other night on glass it was turning about 6120 rpm and my mfd showed 55.3..........., i didnt use my GPS but next time i go out i will take it with me, and i'll se what it does on gps.
            I have a 96 SLT 780...I removed my impeller to find out it's a polaris 17-23 out of a Polaris Genesis and it's in poor shape. What size impeller are you running, would a 14-19 have good bottom end and mid range power? Mine has no bottom and mid power really, it pulls hard at 4300 rpm's and above but that's it.
              I am currently running a 96 slx780. Mods include .50 over bore, tdr waterbox, and an r&d intake grate. I weigh 235lbs and my best recorded top speed on my mfd shows 63.7 mph at 6550 rpm. This can only be achieved on a very calm day with slight ripples on the water. I know the mfd is not 100% accurate but I still think I am getting great top speed out of this bike. Hope this helps
                Stock 96 SLX 58.8 mph at 6,310 rpm. Not on glass, but not major chop either.
                R&D intake grate only mod, 205 Lbs rider. In the low 60's when my buddy rides it weighing in at 145 Lbs.
                95 SL 750, 56.4 Mph at 6,210 rpm. 205 Lbs. rider
                Boysen Pro Reeds
                Reed Spacers
                Primer Kit
                O.P. flame arrestors
                CHANGED the exhaust cooling orifice from the 2.3mm to the 1.0mm (gained about 100 rpm)
                skat-trak stator 6 vien
                6 degree pump wedge
                cone extension
                R&D intake grate
                O.P. ride plate
                28 inch sponsons
                Bored exit nozzel
                14/19 swirl impeller
                4 Inch extended pump.
                Anyone have any thoughts as to what the 750 will turn if I switch to a 13/18 impeller? I'm looking for more top end. It's just right on the bottom now. Comes out of the hole like an monster.
                He who dies with the most toys Still dies! So have fun with them 1970 SS 396 Chevelle, 86 ATC 250R (RAD valve,K&N, FMF gold series, bandit XC's), 97 XLT600SP (SLP tripple pipes, reverse, EPI clutch kit), 95 SL750 (all the bolt on's) & 96 SLX
                  I believe that's banging the rev limiter right about there. It is not going to happen without modifcation to the engine.
