I just removed the original fuel pump and the (check valve?) that is right next to it and replaced everything with a Mikuni 3 port pump by running a line to each carb. Now at the lake it seems to accelerate extremely slowly, I can hold it full throttle and it can take like 30 seconds to accelerate to actually going to full throttle. Sometimes if you hold full throttle from idle quickly you can kill it. Is it running too rich now? If so, what do I need to do to make it run as before? Pop off pressure? What tools/etc. do you need to adjust the pop off pressure, I have the factory service manual but it's confusing.
94 SL650, Just did fuel pump upgrade, now problems
