Hi,
I'm new here and don't know much about engines, so please bear with me.
A compression test on my SLT 780 revealed that the cylinders were; 100psi, 0psi, 100psi. So the mechanic at the small garage near my house told me that an new cylinder is going to be $780cdn, so he recommended going with oversised pistons for all cylinders and boaring out to first oversized since it will be cheaper. He says the piston will be $143 each, and it will be $50 to boar them out, and the labour for all this will be about 10 hrs at $65/hr. He figures the job should come in around $1200. I've attached some pictures below of the bad cylinder and piston.
Does this seem reasonable to you guys? It seems a little high to me, I'm not even sure I can afford it. Do I have any other options?
Thanks in advance for any help,
Ryan
Ryan
