what is the best way to clean a oily hull.
oil in hull
Re: oil in hull
I had oil in my hull. Alot of oil. I basically had an empty hull when I started cleaning: No engine, I removed the gas tank. I used some dish soap. I figured if it can clean grease it can clean oil. I also figured it was mild enough not to hurt anything. It didn't work as good as other solvents (ie: Engine Degreaser), however, I felt alot better about using it inside my hull. With a little scrubbing & the garden hose it got the job done.
Dan
