im new here. i have 2 clear tubes, 1 of them being conected to the impellar and leading to the computer display and the other is connected to a plack rubber thing with a hole in the bottom and the otherend not connected to anything. this may not make sense but does any1 know.
Need help with virage 02
Re: Need help with virage 02
If you are talking about what I think you are speaking of, then yes, that second tube you metioned needs to stay disconnected as it alows the battery to blow off and release heat...the first hose may be your speed sensor, although I am not sure because I do not have a picture to go by...If you could post a picture of both tubes, it would help out greatly...
Normally, speed sensors run on a clear tube as they use pressure to calculate speed...hope this helps,
BarefootPolaris
