I have a 1995 polaris 750 and it gets a spark but you can only tell if you hold your fingers on the end of the spark plug. Other then that you cant see one not even in the middle of the night. I took the flywheel off and looked at the stator and cleaned it i didnt see any really noticable problems then i put it back together and still absolutely no change.
1995 Polais 750sl weak spark
This topic is closed.
Re: 1995 Polais 750sl weak spark
