As the title states, I turn on the ski (SLT750) and it slowly builds up to 6000 rpm without touching the throttle. The throttle cable is not stuck and the throttle plates are all closed.
Ski specs:
-Fresh carbs (all SBT goodies!)
-New gaskets all around the intake area
-Needles/Pop-off pressure are perfect
-Backed the low speed screws off an 1/8th from spec
-New reeds
-New plugs
-Fuel lines all good
-New fuel pump
-Full battery
-Excellent compression all 3 cylinders
-Doing pre-mix with SBT block-off plate (good seal)
It seems like there is either an air leak (how small of a leak could cause this?) or the low speed screws need to be fiddled with more.
Could it be anything else?
Ski specs:
-New reeds
-New plugs
-New fuel pump
-Full battery
