It's runs really good one weekend a next one 3600 RPM then he cuts out. The fuel gauge is working I removed the sensory checked it and it's good. Remove the oil sensor it also checks good. Would the CDI box have anything to do with this.
Help with a SLT 750
Re: Help with a SLT 750
Check compression on each cylinder and post back with the readings. Sounds like 1 cylinder is dead.SBT Tech Support is here to help with your problems.
