just installed triple outlet fuel pump, new plugs, freshly rebuilt. From idle when pinning the throttle it bogs and stalls When playing with the throttle it takes a bit to pick up speed. Also the machine only tops out at around 38mph used to do 47-50mph. Carbs are factory set all cylinder fire but rpm's max around 5000-5300.
Thanks
Thanks
