I have a 95 polaris slt 750 it starts and takes off great but when you got to spin or just turn quick it does not pick back up quick it takes a little bit for it to pick up. cleaned the carbs and changes the internal filters,reeds are good compression is about 100 in mag center and pto is almost 120 this is a new STB motor in order to get it to plane out i have to go almost 70 to 80% throttle also I have a small pinhole leak from around the fule sending unit wich is sepperat from the fuel pickup could that be the reason it is not taking fuel right
95 SLT750 no power
