Robraider left this homepage in a response he gave me to a problem I am having with a 92 Polaris 650Sl engine coupling removal.
I have just removed the driveshaft from 92 Polaris SL650 and, as expected the front spline (connected to rear of engine) was stripped. Now the problem is replacement of the engine rear coupling. It is froze in place. The service manual indicates to place a rope in the rear cylinder head and turn the engine coupling counterclockwise. Well, I made all the way to placing a wrench on it and putting all the muscle I had and I still hasn't broke free. I have added some WD40 and Liquid Wrench to the coupling yesterday hoping this would help. But it is still tight this morning.
Rob indicated I needed to get a fly wheel holding tool. then get a pipe wrench to remove the bad coupler and use a cheater if neded. He also indicated I could use a little heat.
Questions:
1. Am I turning it the right direction. I am assume counterclockwise is referenced from looking from the rear of the engine....is this correct?
2. Should I heat up the flywheel, so that it expands and not the coupling? Also, can I use a propane torch and will this cause any problems internal to the flywheel?
3. How much pressure (torque) should I expect to use. I am concerned about damaging the cranckshaft or pistons.
Steve
p.s. I am using a Crescent wrench since I do not access to the special tool that slides into the coupling....
Questions:
Steve
