Yesterday I caught some great air on the river. But after I landed the motor started running poorly. I could only use 1/4 throttle to get back to the dock. I removed the spark aresstor and found grayish slime on the throats of the carbs. (water) I then wiped out what I could and test ran. Theere was some improvement then at an instant the boat jerked and full power came back. So I thought all is good. So we went back out. After running at part throttle for a little while I went to open it up and found no top end. So I rode a little longer then performance dropped again. I headed in and brought it home. At home I pulled the plugs again seem ok. Also the carbs were pretty clean, sparyed just a little carb cleaner after wiping them out. Started it up idles fine, has a snappy response to the throttle. But if you hold it wide open for a sec it does not run smooth. Any help is appreciated.
PS: I called a local Polaris dealer, who used to deal with watercraft (where I bought it), and he said it *might* just be the rev-limiter? Any thoughts?
