Is there a way to test the Oil Injection system on a 95 Sl 650? I burnt a cyl. due to no oil on the center cyl. I would not like to burn it again. I am currently running premix. 40-1. Any help is greatly appreciated.
Sl 650 Oil Injection Pump
Thank You, But can you tell me basically what does it involve. I think I should be able to T into the lines going to the Injection Nozzles and see if there is any Pressure when the engine is running. If this is not doable what can I expect to pay as a reasonable price or how long should it take a competent shop. Thanks for any help.
Most shops can't do it either - you need to spin the pump counter clockwise at 7000 RPM and measure the exact output of each injection line.SBT Tech Support is here to help with your problems.
