I have an 89 SP that has the buzzer warning constantly beeping. It does a faint type of on/off/on/off beep, though it never goes all the way off. On a volume scale: 10/5/10/5 etc....I was told this is the over heat sensor warning and that by removing the wire connector from the sensor on the top of the engine it should stop. It does not. The buzzer continues even if the ski is not running, cold or warm. Also, since this problem began, the ski sometimes does not rev up at all. I've been told this is a RPM limiter kicking in. Again, sometimes you can rev it up with no problem.
Questions: 1. Does the buzzer only reflect a message from the overheat sensor or is there another sensor that could be causing this? 2, Does the RPM limiter (if any) symptom have anything to do with buzzer?
Any help is greatly appreciated.
Thanks.
Thanks.
