where is my fuel filter is it easily accesible??? also today out riding i sucked up something and it almost stahlled out then all of a sudden it spit it out and took off .. how can i check for damage properly ??
fuel filter location for rxp and other ??
Re: fuel filter location for rxp and other ??
i climbed underneath and i can visually see some stuff ie twigs leafs and plastic but it is too far to reach .. can i safely take the grate off ??? what should i do?? and how can i make sure i didnt do damage#*@* ME IF IM WRONG ... BUT HAVENT WE MET BEFORE?
The fuel filter is in the bottom of the gas tank with the fuel pump.Bill O'Neal, owner of Watercraft Magic in Glendora California, www.watercraftmagic.com
Just pull the pump off and check it. It's easier to clean any debris stuck between the impeller and wear ring with the pump off. It only takes a couple minutes to pull and then you can check ring and impeller too.
