i have a 97 gsx that runs and revz fine on the trailer and fine in the water up until about 5000 rpm.but once you try and go wide open under load it will miss and decrease in rpm until you feather the throttle and start the process all over again.it will do it just sitting on the trailer in the water you dont even have to ride the machine.the machine was running fine until this problem suddenly occured.
there is no warning of any kind on the gauges.i have had the carbs apart twice screens are clear everything looks good,blown out fuel lines and drained tank of all old gas,petcock is new,fuel sender in tank is new.plugs are new and are of the resistor type,exhaust hose looks and feels good and doesnt appear to be collapsing,comp is good 180lbs in each cylinder,rave valves move freely and bellows appear to be in good condition.the only thing i havent tried is putting an inductive timing light on the wires to see if either or both plugs wires are losing spark when this problem occurs however i plan on trying this tomorrow.
any recomendations or suggestions would be greatly apreciated.
thanks cliffy
thanks cliffy
