Oil Pre-Mix for 93 Seadoo XP
  • Oil Pre-Mix for 93 Seadoo XP
    I purchased an engine from SBT and just finished the 10 hour break-in. I disabled the oil pump and need to know the gas-oil premix ratio for regular use. Thanks in advance for the help.
    Re: Oil Pre-Mix for 93 Seadoo XP
    40:1
      Thank you very much for the quick response!
        What type of oil should be used. We just got a 650 for a 94 SPX from SBT and are going premix on it as well. Should we use the SeaDoo oil that we used in the injection system or something else? I know we need to leave oil in the tank for the lower part of the engine.
        Thanks,
        Ian
          Yes, you need the Sea-D00 oil.
            WOW that was faster then the speed of lite for a reply. Should we be using the synthetic or the regular and at 40:1?
            Thanks again!
            Ian
              Regular.
