Re: 650-650X What's the difference?
You don't answer your phone at work.
Yes I take AMEX.
The rideplate extension that I have is the one that has the bolt holes even with the rear nozzel holes in the pump so that the vertical plane of the mounting surface of the plate is aligned with the end of the oem plate.
Some rideplate extensions have an offset because the back of the pump is recessed and not flush with the rear of the oem rideplate.
Yes I take AMEX.
