it goes right under rubrail in front where does it attach to on they other end. the ski is a95 xp 800 any help is appreciated thanks
vacum line on hull up near gas tank?
Re: vacum line on hull up near gas tank?
If it is a 1/4inch grey hose it goes to the fuel tank vent hose that has a Y in it with the other hose to a fitting up by the steering head and the third hose to the top of the gas tank.Bill O'Neal, owner of Watercraft Magic in Glendora California, www.watercraftmagic.com
I traced the vent line from the battery and found it laying in the hull underneath the storage compartment. It appears to be missing the gromet and the hole is plugged on the outside of the hull. What if anything may be discharged through the vent? Vapors I'm sure. As long as there is no liquid discharged should I repair it or is it okay as is?
You NEED to repair the fitting and vent the HYDROGEN GAS to the outside as desined, otherwise you can blow up - litterally.SBT Tech Support is here to help with your problems.
