My kids had our Seadoo GTX RFI towed and water got in the system. I followed manual and did the following : removed plugs, grounded cables on supplied connections, turned the engine over to expell water several times for 10 seconds each time (seemed like a lot came out), sprayed wd-40 in spark plug holes, turned engine again for 10 seconds (twice) and reconnected plugs. It took many times to get it started, but it finally did. I am not at lake and I am starting in driveway. Not knowing how it will affect the engine I only run it a few seconds. (what is safe out of water run time) Any other actions needed. I don't know if I got all water out or not-can't be sure. Is it likely to be allright or should I run it at lake and plan to change plugs again. I'll be headed to lake this weekend and I am trying to be ready. Any tips will be appreciated.
Since writing this I've read the grave reports of "water in engines". Considering the above happened 4 days ago, and I just did procedure today, am I in for major problems. Should I even take to the lake or straight to the shop.
Hamp Lindsey
Hamp Lindsey
