Anyone ever replace the oil tubing 96xp
  • Anyone ever replace the oil tubing 96xp
    Wanted to replace the oil injector tubing while I ahve my engine out.
    Anyone ever do this?
    What did you use to hold the tube on the barbed fitting?
    Would wire ties do the trick?
    thanks!
    Ohio96XP
    Re: Anyone ever replace the oil tubing 96xp
    Yes, tie wraps or wire ties, is what I use.
      Thanks once again !
      Jon
      Ohio96XP
        Would like to replace mine too, What type tubing are you using and where did you find it? Need something that will hold up to 2 stroke oil without becoming hard (like mine are now) and will not dissolve.
          Mark,
          I ordered the tubing from a sea-doo dealer locally.
          I figured it lasted since 1996, it should last me for as long as I'll have the ski.
          www.ronnies.com
          for sea-doo part numbers.
          Jon
          Ohio96XP
            I was hoping someone would have a lead on buying the right stuff in bulk (by the foot). My ski uses 9 separate hoses and as with everything else for a PWC, to purchase them precut to length is mucho denero just for a few feet of hose.
              Call www.parkeryamaha.com and see if they sell it by the foot.
                Hobby shops carry this hose, very cheap prices.
                  Will check it out, is it the same tubing used for glow fuel?
                  Thanks,
                  MC
                    Larger shops will have a variety of hose sizes - Get the stiffer variety.
