the first start up
  • the first start up
    i know that these motors can be started without being in water but when i do the first start up after putting in a new motor should i do it in the water. 95 spi w/o oil plate got it all together but a couple of fuel lines and exhaust. anything i should look for like smoking that is normal but may seem odd. thanks for all the help this site and this company do a great job in cust service i was sent the wrong tracking number so i called and they not only gave me the number but also tracked it for me too while i was on the phone thanks again
    Re: the first start up
    You Can Run It On A Hose For 3-4 Minutes To Check For Exhaust Leaks. The Motor Should Smoke More Than Normal If You Have Your Oil Premixed Properly To A Break In Mixture. Set The Idle Out Of The Water To Approx 2800-3000 Rpm And Go To The Lake. Thats The Only Way To Properly Check Performance, Look For Any Other Leaks And Break It In.
      explain the break in mixture?
      :D
        You Say Without Oil Plate. Do You Have The Oil Pump Installed?
          i'm actually refering to a new motor going in my 97 gtx stock oil system, any special precautions after bleeding the sytem?
          :D
            If You Are Running The Oil Pump Then Premix The First Full Tank Of Gas 50:1 Oil-gas Mixture.
              thanks..........Scott
              :D
