Here are the symptoms: (94 sea doo xp with oil block off (if that matters))
Been sitting for about 9 months while i repaired exhaust
Got it all back together and it would not run, pulled a plug for spark and turned it over I have spark but also had a shiatload of sludge that looked like oil come shootin out, did not really smell like oil or gas.
Pulled both plugs, throw a rag over the holes and pushed all the crud out.
Put plugs back in and it will fire but only run for a brief moment then die.
If i spray a starter fluid in it will continue to run.
Tank is full of fresh gas, it was almost empty before.
Ran fine before exhaust broke
Any suggestions on where to go from here?
Thank
Toy
Thank
Toy
