Hey i was told my 97 xp carbs has a excellerator pump on the rear carb? I was wondering if i could use the carbs off a 96 xp with no excellerator pump, or would i have to change anything. thanks
787 carb?
Re: 787 carb?
97 xp had 65 pilots and 142.5 mag 147.5 pto mains
96 xp with 70 piolts and 142.5 for the mains
With 96 carbs on my 97 xp i have R&D intake grate, west coast flame arrestor, and R&D head for pump gas, i thought i had the 97 xp jets and was told to bumb up to 70 pilots 147.5 mag and 150 pto mains, but is that gonna be enough since i got 96 xp carbs? thanks im really confused
Re: 787 carb?
Yes, those 70 low speed jets should work in your 1996 carbs with an airfilter kit on them, but you will probably need to open the low speed adjusters a bit to get them to accellerate, or use 75's.. Use the 147.5 main jet and the 150 main jet.Last edited by Bill O'Neal2; 09-13-2004, 01:23 PM.Bill O'Neal <br>
Re: 787 carb?
Hey finally got to take the ski out today. Shes a bit sluggish on bottom end then she screams all the way up to wot. i have the 96 xp carbs on my 97 xp jeted at 75's 147.5 and 150 jets with lows turned out 1 1/2 and highs at 0. what should i adjust the jets to get the out of the hole sluggish gone.
Re: 787 carb?
Try turning them in a little to get rid of a bog, or out a little if it hesitates when you hit the throttle.Bill O'Neal, owner of Watercraft Magic in Glendora California, www.watercraftmagic.com
