good question
  • good question
    When i start my 96xp out of the water on the trailer it sounds like my impleller or something down there makes a horrible rattleing noise after its been on for about 4 seconds. I have owned many other xp's before this one and have never heard that loud annoying sound. Ski runs fine though
    thanks,
    Re: good question
    the death rattle is normal , but you might want to pull the pump and check for driveshaft bumpers , also check the pump for oil and grease the splines to be on the safe side .
      Re: good question
      Isn't it horrible for the impeller to run it out of the water. i would think it would cause premature wear on the wear ring?
        Re: good question
        Being that you have clearance between the impellor and the wear ring, NO, it doesn't hurt anything to run the pump out of the water.
          Re: good question
          Just don't do it for very long as, I think, those pump bearings depend on being submersed for cooling.
            Re: good question
            The driveshaft bearings get really hot after a few seconds........
              death rattle
              are you sure, i have a had a couple other skis before this on and no others had that horrible sound. is there someway i can get rid of it
              thanks
                Re: good question
                Remove your driveshaft cover and pour a cup of water onto the carbon seal. It will stop the noise for a few minutes ( if that is really the noise you are hearing). Yes, it is normal, no it will not hurt anything. The noise goes away when you put it into a lake.
                  Re: good question
                  Ok, i'll take your word on it. I am almost 100% sure that sound is coming from somewhere around the impeller though. What is the carbon seal? Is it underneath the flywheel cover?
                  thanks,
                  eric
                    Re: good question
                    THE NOISE IS AWFUL IN MY GSXL BUT IN THE XP99L IS NOT SO CLUNKY, anyhow those pumps are just fine both, so i would say dont worry about it
