Is there a gasket that is supposed to go between the Stinger pipe and the pipe leading to the waterbox? It looks as if the previous owner used an orange gasket maker.
Is there better way to separate this connection other than backing the nut all the way off the band/clamp?
This is on a 97 GSX.
My last post asked about my new SBT I just installed. It ran for about a minute and stalled, and hasn't been able to start back up again. I was referred to the infamous SBT carb rebuild diaphragm problem. Should I have pop-off checked before changing to OEM diaphragms?
