I compared the specs of a 657 and a 657x to a 717 and found there are many differances between a 657 and a 657x. Such as carburetors,main jets, pop off pressures,Ignition timming,compression Ratio,Rotary valve,and a few more. When I compare the specs on a 657x and a 717 there are very little differances, which are, Main jets, Pilot jet,Pop off pressure,Bore,and displacement.Is the 717 just a bored out 657x?
If so, will the rotary valve cover, intake, exhaust and the electrical componets from a 657x fit on a 717 with any problems?
Does a 717 have oval ports as a 657x has?
