03 Gtx 4tec Supercharged Won't Start
  • 03 Gtx 4tec Supercharged Won't Start
    After riding for a half hour or more then shutting the engine down, The engine will not start and there is no display or beeps, and no indication that the key was inserted, if I wait a half hour or much more (depending how long I've been riding) it seems the engine will cool and it will restart. There are no warning lights that come on prior to shutting the engine off, this has happen to me several times. Any help would be greatly appreciated.
    Re: 03 Gtx 4tec Supercharged Won't Start
    when you say turnover , is that the motor will not crank or crank but not start ?
      It will not crank, there is no indication that the key was inserted, it seems a safety switch cuts all power to the ignition system.
        THere's really nothing you can diagnose yourself. You need to take it to a Dealer.
          if it is under warranty drop it to the dealer , if not check for loose or dirty conections , pull the plugs on the mpem and check for water .i have seen a few 4tecs with bad DESS post that would do close to what your having a problem with .
            check the fuse holders next to the start solenoid to see if they have a firm grip on the fuses.
